02.28.2008, 08:37 PM
OK, I did a little playing around with the Novak 4s LVC. The internal resistance of the unit is 200k ohms. So, depending on how much of a delay you want, you pick a capacitor that will discharge to ~12v using 200k ohms as the discharge resistance.
Since the internal resistance is constant (and it is because I checked), you don't need the additional discharge resistor shown in my original diagram. So, the new diagram looks like this:
I created a little Excel spreadsheet which helps to pick out the proper capacitor for the delay you want. Just fill in only the green boxed areas.
  • Resistance (ohms): Enter the LVC internal resistance, 200,000 in this case.
  • Capacitance (farads): I used 22uF. Other common values for ~25v are 10uF and 47uF, but don't provide the right delay IMO, but that's up to you.
  • Battery Voltage: Self-explanatory. Use the nominal battery voltage. For a 4s pack, use 14.8v.
  • Time Constants to show: Caps are accepted to be charged/discharged in 5 time constants, but if you want to see more detail in the lower time ranges, use a lower number.
  • Euler's number: This is a constant for natural logarithm base. Leave as-is unless you really want to mess with it.
The table will show the time, discharge capacitor voltage, and charge capacitor voltage. And the graph will reflect this.
I figured a delay of ~1 second before the cap reaches LVC threshold of 12v should suffice, while still retaining full LVC functionality. So, for a 22uF cap, the discharge voltage is at 12.033 at 0.91 seconds (use 0.3 for the "time constants to show" to view this). If you use a 10uF capacitor, the cap will discharge to 12.033v after 0.41 seconds if you wish.
That's about it. Don't forget the diode or this will not work. Germanium works better because of the lower voltage drop (0.3v compared to the 0.7v of a normal silicon diode). Also, don't forget that the LVC will trip a little earlier because of this voltage drop. Any diode with a PIV value >= 100v will work fine, so 1N4002, 1N4002, etc.
