Thread: FLM VXL Pede
jadesportster
02.28.2008, 08:45 PM
Are any of you guys running FLM ext chassis with the venom F350 body get wheel rub up front toward the front of the bumper? It was pronounced at first, but I adjusted the front suspension on the shock towers so the front would sit a little higher but under hard braking and turning together, the wheel rubs a little bit.
I'm wanting to avoid trimming the body as it will never match on either side. I'm running 1 degree of camber up front, but with the shock fully compressed, the wheel kicks in considerably more
I'm running big bore alum shocks with the stock springs up front and a 6 mm shock dampner clips and trinity blue's in the rear to reduce sag.
What's the best setup for the FLM chassis?
