Sammus
Sammus's Avatar
02.29.2008, 05:15 AM
I reckon an old toothbrush and some metho. Dunno if its called that in the states, its basically ethanol with a bit crap added so they dont have to pay regular alcohol taxes and so hobo's cant drink it. Air compressors are also good.
BEWARE though - DONT blow pressure air or anything near your bearings, all your doing is forcing little bits of grit inbetween the seals, and you will make them fail MUCH quicker. Soak a tissue in metho and wipe bearings carefully, spray them with some lube if you want and they should last you a lot longer.
