lutach
lutach's Avatar
02.29.2008, 09:08 AM
That is a great price on the rotors, did you get them from hacker directly? I see that their site is under construction at the moment.
Also did the kv change with the different rotor? I guess that I could contact them about repairing the shaft? Not much point if the shafts are so cheap. Wonder if I can get it with a 5mm shaft?
I have a c50 14l in my new emaxx on 5s and it is killer, plenty of power!
And I have read that the b50 motors have different magnets than the c50 motors. The c50 appears to be better, as it has segmented magnets, like a lehner.
You can contact them directly and just ask them for the rotor for a C50-13L and they will send you a the rotor with 5mm shaft. I couldn't give you any info on Kv change, because I didn't use the C50-Maxx due to the broken shaft. All I can tell you is that the motor on 4S lipos is awesome. Hacker uses thin disc magnet and they wrap them with Kevlar. I have never opened on of my B50, but the C50 I think is a higher quality motor.
