Originally Posted by BrianG
Not yet. I know they made changes for the Neu motors, but wouldn't think they would change the starting algorithm... I'll have to check it out.
I believe they have changed the starting algorithm. I tried it before with a 12 pole outrunner setup. All it wanted to do was cog, and act confused on directional control, before it thermally shut down.
Now I'm running my E maxx using an AXI 2926/8 12 turn outrunner. I do have a fan on the MM and a CC BEC being fed by 4S Lipo, 5000mah 20C.
I can't make it thermal, the ESC runs cool. I can't MAKE it cog either. It has great low speed driveability. Even on the very first step of the throttle at the controller.
I pulled a Monster Pro 125 amp to give this a try. I think I'll just leave the MM in there.
It is every bit as smooth now, perhaps even a little bit better.
If you have one laying around, try it and see.
