Thread: 5s vs 6s
lutach
lutach's Avatar
02.29.2008, 03:04 PM
both sound great to me.
With all other things being held equal:
5s + 1515/1Y:
- expected rpm @ 18.5v = 40,700
- battery is cheaper,
- will run slightly warmer (but not hot),
- has slightly less efficiency, and run time. Which you may or may not notice, depending on how critical you are.
6s + 1515/2.5D:
- exp rpm @ 22.2v = 37,740
- more expensive battery (you could always buy another ma 8000mah lipos and wire your existing one in series, so maybe not).
- will run slightly cooler, be more efficient, more run time.
echo.... echo... echo....
Here is some more info:
1515/1Y, 2200Kv, 7-25 volts and 110A* (Good batteries are expensive)
1515/2.5D, 1700Kv, 7-35 volts and 80A* (I ran 22.2 volts for 23 minutes using 2200mAh 3S packs)
(*30 sec. at max. voltage. Otherwise, = Watts/your voltage).
