crazyjr
crazyjr's Avatar
03.01.2008, 03:31 PM
If the pinion is not symetrical on the teeth /\ , If there is a slight tilt away from the foreward side (looking at the spur side of the tranny) the wheel turns clockwise, the pinion goes counter, so if the point of the pinion is towards clockwise , then every time you brake it tears up the spur a little bit Till failure
