sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
03.03.2008, 05:12 PM
Originally Posted by Just go Play View Post
Sleebus: Were you able to get the speed function to work (I saw your post on eagletree forum) properly on your V3?
No, I hadn't played with it any further. I will have to one day. :)
Is the 150 amp going to be enough? I know a lot of guys with the 100 amp system were running up to 120 amps (max reading) and needed more. It would be nice to know from someone that has the 150 amp system, if they are maxing it out as well. If it is enough (probably would be for my buggy at least), then I may have to get one.
My first run out of the box with mine I hit 156A. No ill effects. :D However, I'm not sure what the max reading is.
Sleeb
