03.03.2008, 07:23 PM
Use that brace that Brian linked to, and make sure you threadlock all the screws. I had the same problem and went through several spur gears despite having the brace installed. I took the entire mount apart and threadlocked everything, including the motor screws. Not a single problem since then.
J.
