offroader
03.03.2008, 10:57 PM
Originally Posted by Shark413 View Post
Hi offroader, yes I considered a "Y" harness. One issue is when you pull the throttle on your radio the brake servo will move to the on throttle position as well. More wear and tear on the servo. With brake mixing on channel 3 the servo does not move when throttle is applied. Thanks for the comments.
Good thinking I never even thought of that extra wear on servo's I'm guessing it must draw extra power too. Thanks for the heads up.
