Sammus
Sammus's Avatar
03.04.2008, 10:17 AM
Originally Posted by BOOGIE444 View Post
You have a revo with the turnigy HV esc and 11XL right? How fast is that setup on 6s, what kind of lipo are you using? What kind of temps are you getting, and runtime?
Sorry to sound like a question box but not too many people have experience running the exact same setup I am looking at getting.
I run my own made packs, they are two 3s1p 4000mah HECELL U series Gen 1 cells (toted as 20C continuous, 25C surge) run in series.
I haven't been able to take it for a real good run since completion - I love building them but rarely get a chance to run it. I ran it with full packs for about 10 mins out the front, did a few high speed passes and generally just drove around a bit on the empty road - I haven't gone through a full pack yet, but with my batteries I'd estimate at least 15min runtime in my driving conditions.
I run 16/38 and the top speed is pretty nuts - easily as quick as the stock 3.3, even a bit quicker with heaps more torque - it wheelies in second pretty easily.
I haven't noticed the batteries get any warmer than ambient. The ESC gets maybe marginally (4 or 5 degrees C) above ambient, and motor is running a RCM heatsink and is the warmest of the setup - but nowhere near bad warm. I haven't got a temp gun, but can easily hold my hand/finger on the motor can for as long as I want without it burning. Just feels a little warm, maybe 40-45C at a guess?
I'm sure if you were going hard in the dirt with the motor revving a lot harder you would get higher temps.
That said, its a pretty sweet budget setup - don't count on racing with it though. The air ESCs have a soft, low torque start to protect aeroplane gearboxes. While this (i imagine) would massively reduce peak current draw, it also leads to a bit of a delayed response if you back off then gas it again. This pretty much makes it near impossible to power slide or balance it properly in mid air.
Also as a warning, on my brothers (running in a savage), his brakes were very slightly engaged when he first set it up, blipping the throttle with the wheels in the air made smoke pour from the ESC after about 30 seconds. Disassembly of the ESC revealed a black mark on the PCB, but nor near any components at all. It hasn't seemed to affect the function of the unit at all, but maybe he was lucky.
Sorry for the long post
Cheers
Sam
