03.04.2008, 05:19 PM
I think I have a 16T in my CRT .5 I could swap them over.... eeek to fast on CRT .5 on 3s - 2s would be ok...
Differential Ratio: 4.3
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 16
Total Voltage: 16.5
Motor KV: 1600
Tire Diameter (inches): 6
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 2.88 : 1
Total Ratio: 12.3625 : 1
Tire Circumference (inches): 18.85 inches (478.78 mm)
Total Motor Speed: 26400 RPM
Vehicle Speed: 38.12 mph (61.23 km/h)
Effective Speed Rate: 2.31 mph/V (3.71 kmh/V)
Estimated Adjusted Speed: 36 mph (58 km/h) - 5% loss
Effective KV Value: 1600
Differential Ratio: 3.25
Other Ratio: 1
Pinion Tooth Count: 18
Total Voltage: 11.1
Motor KV: 3511
Tire Diameter (inches): 3.8
Motor coil Ω: 0.0059
Spur/Pinion Ratio: 2.56 : 1
Total Ratio: 8.30556 : 1
Tire Circumference (inches): 11.94 inches (303.23 mm)
Total Motor Speed: 38972.1 RPM
Vehicle Speed: 53.05 mph (85.21 km/h)
Effective Speed Rate: 4.78 mph/V (7.68 kmh/V)
Estimated Adjusted Speed: 49 mph (79 km/h) - 7% loss
Effective KV Value: 3511
