Thread: Which motor?
03.05.2008, 03:11 PM
Given the higher amp handling abilty of the esc you have, it should be fine to run with the 7xl so long as your truck isnt a 12lb tank. Whatever gearing you were running with the 8xl (assuming it was 'good'), then I would suggest to go down a tooth on the pinion to maintain a similar speed/temp with the 7Xl motor.
