Originally Posted by Topas
Today I received my mgm 22418 car esc. (I bought a new one) This one was shipped with sw V 3.21 .
Due to bad weather conditions I could try it in my new emaxx (motor : kontronik fun 600-25) for only 20 minutes or so. (at 16,8 V)
At first I had some problems in setting up the esc (setting max. break and max throttle + I didn´t know if I should enable freewheel).
Furthermore I noticed some breaking problems with the default car setting. I drove the emaxx with medium speed and tried to stop (max break) but the car increased the speed and was stopped by the front wheel of my car ...! After changing the deceleration value to very hard1 2,3s the problem was gone.
I have to install my eagletree logger to support my feeling that the motor runs hotter on the mgm as on the kontronik jazz 80 but there was no cogging and the motor ran very smooth.
I might be having a simular issue with my MGM 16024. It goes forward, but when I hit the brake it still goes forward and then it brakes. If I continue to hold the brake the car would continue to go forward. Is this the problem you had?
