rschoi_75
Certified Spaceball
rschoi_75's Avatar
03.06.2008, 02:19 PM
Originally Posted by JerryF504 View Post
I wonder how the new Swinder Micro would work. It doesn't have an actual value under the continuous rating. It just says "More than you can handle!"
Yeah I read that and laughed. The new sidewinder micro is supposedly just a mamba 25 with a new sticker. I think they bumped it down to make room for their new Mamba Micro Pro, which is supposed to have a 35 amp constant rating. (I got this info from another forum).
Skellyo, the dimensions of the battery tray are 90mm L x 34mm W x 15mm H. Its a little longer than a standard MQ battery compartment since the XTM rage uses end caps on their stock shotgun style batteries. The height can always be changed by raising the battery posts. One thing to note, the xtm rage's battery compartment is molded for nimh's, so you may want to dremel off those ribs as well. The dualsky lipo I mentioned is the same lipo that will fit in a MQ. They currently have a 1300mah 25C lipo that fits perfectly.
rcm xt8
rcm xb8
rcm crt.5
