Originally Posted by lincpimp
the ccbec is only good to 6s lipo. This may be some issue. Your factory am radio system may also be causing some problems.
Correct, but I'm running it off the series connector which only pulls the votlage from one side only. So its seeing only 5S max or 3S or 2S depending on the batteries I'm using.
