snellemin
2 KiloWatt RACER
snellemin's Avatar
03.07.2008, 06:39 PM
What did u do to keep the front down on your rustler and what tires will you be running? I like the jato shaft myself and run 32p gears with no slipper.
You will be probably faster in a dragrace if you keep from lifting up and reduce tire slippage. If the race is around 200ft, the better driver will win.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
