03.10.2008, 07:53 PM
Thanks for the compliment Lincpimp. Arct1k, there is about a 5mm gap between the servo saver and and rear motor cover. The wires do not rub at all when I steer. Two of the motor wires are facing inward, so they cleared it fine, and one is sticking upward and it has about 2mm clearance from the servo saver. I weighed the truck without batteries with a home scale 10 times and it says the truck is 8lbs. I didn't think the scale was accurate, so I weighed 10, 20, 25, and 45lbs dumb bells and scale is weighing those correctly. The reason why I went with this esc/motor combo is because both of these were in stock at the same time. I was planning to use mm / 1515 1y, but the 1515 1y was out of stock very quickly when rc-monster got them back in stock. So far, I like this setup. It lets me use 8s or 12s lipo, which i'm planning to use on it.
