Lonewolf039
Lonewolf039's Avatar
03.12.2008, 11:33 PM
OK, I finally got a couple of days off and got my Evo together. Still need to do a few little things like clean up the wires some more and play with the settings on the MM. The 50% brake setting gives instant endo's I found out, very powerfull brakes. I am running 50% punch control as well, and really like the smooth power delivery, and it will still wheely on demand. The Trakpower batteries are awesome, they hold their voltage right until the cutoff, and I have it set at 3.2v/cell as an extra safety margin. I ran 4 packs so far, and the temps were really good. 120-140 on the MM esc with no fan, 90-105 on the motor and room temp on the batts. I am running the 14 tooth pinion for now, can go up if I want to go faster. Speed calc says 37-38 MPH, which looks about right.
Differential Ratio: 4.3
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 14
Total Voltage: 14
Motor KV: 2084
Tire Diameter (inches): 5.8
Tire Ballooning (inches): .25
Motor Current Draw: 0
Motor coil Ω: 0.0073
Spur/Pinion Ratio: 3.29 : 1
Total Ratio: 14.12857 : 1
Tire Circumference (inches): 19.79 inches (502.72 mm)
Total Motor Speed: 29176 RPM
Vehicle Speed: 38.7 mph (62.17 km/h)
Effective Speed Rate: 2.76 mph/V (4.44 kmh/V)
Estimated Adjusted Speed: 37 mph (59 km/h) - 5% loss
Effective KV Value: 2084
OK, now for the pics
Not real happy with the wiring yet, like to get it a little neater.
Had to clearance the hump a bit to fit the smaller pinions.
I love how simple this setup is.
