03.13.2008, 11:52 PM
Glitch may be the key word. Your radio antenna being sandwiched between all those motor wires could very well be the problem.
I wouldn't suspect the soldering if it takes off hard and only has the problem at a higher RPM, as most of the amps are pulled getting the vehicle into motion, not as much speeding it up...
