03.14.2008, 10:09 AM
I am very happy with the kb so far. I have put about 2.5 packs thru it, and everything seems to be staying cool. It has quite a bit of power, and cand draw the batteries pretty hard at full throttle. I have the punch control set at 20%, and may move it back up to 50% for less wheel spin out of the hole!
The solid center gives it a different feel to a buggy, but I am used to it from driving shaft drive 10th scale cars. Still prefer the diff in a buggy, but it is cool drifing this big car around the parking lot!
The mm seems to be ok with this setup. I had a novak cap on the mm, but it fell off. I could not get solder to stick to the joints on the board, so I will attach it to the input leads near the board. The esc ran noticably cooler with the extra cap. I may also put a fan on it, as I have a few 12v units hanging around.
On a side note, what would it take to have the fan temperature controlled? Have some sort of sensor on the heatsink, and a relay or solid state elec. to switch it on and off when needed? Maybe BrianG could whip me up something, given his electrical genius background?!
