Originally Posted by lincpimp
I had a novak cap on the mm, but it fell off. I could not get solder to stick to the joints on the board, so I will attach it to the input leads near the board. The esc ran noticably cooler with the extra cap.
Are you using flux when you solder? I realize that some solders are rosin core and don't necasarily need more flux but I always use it and it makes the solder flow right away and makes a very strong bond.
