Lonewolf039
Lonewolf039's Avatar
03.14.2008, 08:58 PM
Hey Lonewolf039, do you have the RCM hybrid truggy diff in your revo???
Because i've look to make a system like your's but i need a 4.3 diff ratio to don't have to put a 5T pinion and stay in the 40 m/h range
Yes, I am using the 4.3 ratio hybrid truggy diffs. Like you said, it's the only way to get the gear ratio in a decent range. They are awesome, the machining is top notch, and the HB diffs are way beefier than the Traxxas diffs.
BTW, the Traxxas cvd's fit in the HB diff outdrives perfect, but they are a little short and barely stay in, so I used the RCM adapters and the Traxxas dogbone cups. I am curious as to how the Traxxas cvd's will stand up to brushless power.
