03.14.2008, 10:01 PM
just to know my setup, it worked fine with a 2pole kb45xl using the same ds8411 digital servo in the maxx. no its hooked up to a hacker 50L (not sure of pole maybe 4) and thats the only difference. everything else was simply moved over from the other truck. it worked everytime before. i've messed with the wire alot, and even hooked up a ccbec after pulling the red off the esc plug. no change.
what setup are you using?
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
