Lonewolf039
Lonewolf039's Avatar
03.14.2008, 11:01 PM
So, made any progress on this? I am anxious to see how it turns out.
BTW, a 5/8" drill bit is 15.88 mm. That is what I used for my bearing holes, and then just carefully opened them up for a snug fit with a sanding drum on my dremel. For $96 you could have bought a cheap drill press and some drill bits, then you can make all the holes you want
