BOOGIE444
03.15.2008, 11:30 AM
If your tires are already glued on just stick them in your oven on a metal cookie tray for 350-400F for 20-30 minutes. Grab some really thick gloves and just take the tire off the rim, when the glue is melted they come off super easy. It will stink in your house for a 1/2 hour after you open the oven but it works great and saves lots of $$$$$
For killing the balloning this will work on any tire. Turn your tire inside out, scrub down the inside of the tire with rubbing alchol and then tape the inside of the tire with duct tape and make sure you overlap the duct tap by at least 1-2" inches. = Balloning permantly done!
