Originally Posted by What's_nitro?
The controller is thermalling so fast mainly because of the 6-pole motor. Think about it. If 2 poles = 6 pulses per revolution, then 6 poles = 18 pulses per revolution. The ESC is working 3 times harder than usual. Add higher gearing and maximum voltage and that's pretty hard on a controller. Do you have a fan you could use on it? I think 5s with a fan would work fine.
I would agree with you, but I can't due to the following. Mega recommends only CC ESC's and they have no issues running a CC ESC that was designed to run a 2 pole motor?!? This leads me to believe that the Quark programming has alot to do with it. Worst case scenario, the guys at CC could maybe speed up the MMM a little( ugh, ugh) and I will go that route. We will see....
