Thread: soldering ?
ssspconcepts
ssspconcepts's Avatar
03.15.2008, 06:50 PM
Originally Posted by damon View Post
What I meant is there are 2 positive battery lines, 2 neg and 2 for each of the 3 motor lines. So both wires have to be connected for the controller to work correctly?
Any pointers on how to solder two fat wires to the little deans connector?
Thank you! Damon
Well, you could use 5.5mm plugs instead of using the Deans connectors. Just make sure use heat shrink wrap the female plugs real good. Also consider using and one female 5.5 and one male 5.5 on the battery (and vice versa on the ESC) to avoid "polarity" accidents.
Deans plugs are great but as you mentioned small and a major PIA to solder two large wires to them.
