Mister-T
03.15.2008, 11:16 PM
It's seem that people forget that the true limit of a system is the power supply, the battery.
As long as you can supply the power to the motor you can virtually move anything ...
Obviously the motor will cock itself if you overload it.
Did you ever noticed the CC rate there motor based on rpm ( no 3S lipo with 7700kv) and not on surge current/ limit of the coil ?
Traxxas choice prove that they aren't new in the domain... the VXL is just perfect fit in 1/10 Traxxas buggy, but doesn't work as well in other situation.
