Finnster
KillaHurtz
Finnster's Avatar
03.16.2008, 04:55 PM
Mine was doing the same thing. It was coming out and tearing up the slipper pads on my Revo. I thought it was the pinion coming loose, as it slipped just a bit.
Was running it yesterday for the 1st time since Nov, ran fine for a bit, then shaft came way out and now the power is weak and its stuttering at low throttle. I think something has happened to the motor...not good as I haven't had it that long..
hopefully you'll have better luck
