03.16.2008, 07:42 PM
Here is what I got:
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1.5833333333333333
Other Ratio: 0.967741935483871
Spur Tooth Count: 49
Pinion Tooth Count: 14
Total Voltage: 39.6
Motor KV: 1000
Tire Diameter (inches): 7
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 3.5 : 1
Total Ratio: 17.73883 : 1
Tire Circumference (inches): 21.99 inches (558.58 mm)
Total Motor Speed: 39600 RPM
Vehicle Speed: 46.49 mph (74.68 km/h)
Effective Speed Rate: 1.17 mph/V (1.89 kmh/V)
Estimated Adjusted Speed: 44 mph (70 km/h) - 6% loss
Effective KV Value: 1000
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
