Originally Posted by _paralyzed_
I had one, there is no bec, hacker told me not to run 4s, it was designed for c50 motor on 12 cells, like an e-maxx
He can give it a try. I would think that motor rpm and load would be more of an issue. The c50 maxx motors are very powerful, and good on 4s lipo. 12 cells nimh are about the same as 4s.
Takedown, I would keep the motor rpm under 40k. That may keep the controller happy. And try lower gearing for your inital tests. Keep an eye on temps, and then go up gradually with the gearing. That should ensure that you do not roast the esc on the first run!
