Originally Posted by jhautz
I personally am not planning to use a motor that requires an clamp/heatsink I will need 6.35mm (1/4") to clear the whole brake mechanism.
this is the size i will need when i get a diff. motor w/o the heatsink clamp
my 4mm + the hs.clamp of 2mm = pretty close to what you came up with
i wish i had a caliper
