03.19.2008, 12:53 PM
A Battery will only output the amount of amperage its asked for. Your controller is the dertming factor of how many amps the entire system can handle. The piece you need to pay attention to is the motor and how many amps it will draw at the speed you run it at. The higher the load the more amperage you need. What are you planning on running these in?
