Originally Posted by kevin1
ok, I had talk with a person who had say to me that for exemple the ACn22/35/1E,
I is at 60A and it is too low, the motor will become very hot,
and in 4s, he give only 950 Watts !
what do you think about this ?
My motor is only rated for 70A and is smaller than the 22/35. Mega uses continuous rating and your motor will put out more power. I've seen spikes of 90A with my motor. Keep in mind that electric motor makes power from torque and the Mega being a 6 pole motor has tons of torque. If you see some graphs from data loggers, you will only see the spike and then the AMPs fall as the vehicle starts moving.
