MM cogging when on ground, not when in air
supralover72
supralover72's Avatar
MM cogging when on ground, not when in air - 03.19.2008, 05:12 PM
I finally had time to charge my lipo, I took my buggy out for her maiden voyage, and she was fine for the first 2 full throttle's, then she went full lock brake by herself, then cogged HEAVILY. Then she'd be fine for about a second or one run, full lock and cogg. But here's the kicker, she seemed fine when I pulled her off the gound.
The only thing that got hot was the ESC and the motor was warm, and this was only after about 60 seconds of runnning.
I changed my programming from 50% punch control to zero and changed the reverse setting to reverse lockout. I also changed start power from medium to low.
Gearing is 15/46 w/8xl and neu 4s
Will this work?
Any ideas?
I don't want to have wasted all this time and money and screw it up. Thanks.
