Originally Posted by david lamontagn
Yes, i'll wear it, but the paint i use is a water base paint, less harmfull than an urethane automotive basecoat
You telling me!
I just sprayed 1.5 gallons of single stage urethane on a huge van, in 30mins. Wide open the entire time! I wear a mask most of the time, unless it is a single panel, like a fender. I can hold my breath for about more than a minute. Auto paint is nasty, especially epoxy!
Sharp work David, gotta work in some "clothing challenged" ladies into your paint jobs! I may even commission a body from you then!
