bdebde
That's All Folks!
bdebde's Avatar
03.20.2008, 10:49 AM
Hard to believe it is 22/46 (according to vid) gearing!
Differential Ratio: 4.09
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 22
Total Voltage: 22.2
Motor KV: 1577
Tire Diameter (inches): 5.7
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.008
Spur/Pinion Ratio: 2.09 : 1
Total Ratio: 8.55182 : 1
Tire Circumference (inches): 17.91 inches (454.84 mm)
Total Motor Speed: 35009.4 RPM
Vehicle Speed: 69.42 mph (111.51 km/h)
Effective Speed Rate: 3.13 mph/V (5.02 kmh/V)
Estimated Adjusted Speed: 63 mph (101 km/h) - 10% loss
Effective KV Value: 1577
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified.
