Thread: Project E-Revo
DickyT
03.20.2008, 10:25 PM
Originally Posted by pipeous View Post
the thing with the center dif, if you go even thicker then it will wheelie more. it's like make a solid shaft down the center. the thicker it is, the more weight it transfers evenly to both axles. with it locked you turn both and it will wheelie. when a center dif unloads under acceleration, you'll see the front wheels ballooning because of weight transfer to the rear, making the front light and power unloads there.
I am not trying to be argumentative, or insulting. just my opinion on difs. personally I like thinner oils in difs so they actually work. center is different than the 2 ends but you get no dif action from dif lock, well very little at all anyway.
try 30k and I bet you'll have tamed the wheelies down, even 40K
I was talking about the center diff, I do not have diff lock in the front or rear, They still have oem grease in them, and the lock lube does not lock center i can freely move it by hand. It is a hair thicker than 500k, but does not lock like silly putty would. the fronts balloon horribly. I've gotten a bit more used to it and can get fast acceleration with out wheelies now, but at WOT with all 4 planted the fronts still turn into dinner plates. I put the spool back in and all it wants to do is wheelie at any speed.
