GO-RIDE.com
03.21.2008, 10:32 AM
I moved to the inner holes on the servo saver and havn't had the issue again...
I tried that myself, but with the RCM extended chassis the car looses a lot of steering in that setting. I think the aluminum steering knuckles have a 2nd mounting hole that quickens the steering back up when using the inner hole on the servo saver. I might drill a second hole in my plastic knuckles to see if I can get similar results.
What I'm hoping to find is a stronger servo saver from a slightly bigger car/truck like the Hot Boddies LS10. Has anyone tried something like that ?
E-8ight - Tekin RX8 2000kv/4S
