Mod Man
03.22.2008, 09:30 PM
Cool. Sounds good.
It looks like you have thought it all through. The one big thing that I have to advise is, if a 611 or another gyro just as fast, is out of your budget, I would say do not even use one. I have run a 401 in cars. They max out in performance at about 60 mph. Above that, they actually cause more problems than they cure. Of course, maybe you could mix it out with your React above a certain throttle?
I run BSR radials. Yours will be different than mine because I run them on touring car wheels.
They are awesome. But, I have shredded one in the past with too much wheel spin.
With two wheel drive, you will need alot of downforce for traction. But, that downforce will ultimately slow the car down. So, look for a good ballance.
Nic Case has alot of experience with 2wd and 4wd cars. Maybe he will chime in here. I may email him a link or call him and let him know about this thread to see if he has any suggestions.
Have fun with the car. That is what it is all about anyway!
Matt
