03.23.2008, 03:36 PM
The arm mounts used on the tranny case are the same ones FLM makes for the Nitro Rustler (so you can use any arm mounts FLM makes for the Nitro Rustler). They use two screws to secure them to the chassis, and the hinge pin hole is drilled differently to obtain either 1deg. or 4deg. of toe-in.
Stock Rustler arms and driveshafts work just fine.
