lutach
lutach's Avatar
03.23.2008, 11:37 PM
Originally Posted by DrKnow65 View Post
Got off way lucky, a moment of not looking and bang, it's done...
MetalMan, what were you doing on the scroll saw for 6 hours??? (building something cool out of aluminum I hope...)
Suicideniel, I've seen some of the stuff about AC brushless motors, but it does look far off for it to go RC...
Dang Luatch, you've looked into the low KV motors!!! What do people use to spin those motors now? Are there already esc's that will do over 40v?
P.S. did you ever try a TCS cooling system? I was looking at some old posts and saw you had interest at one point. I'm thinking about doing a stage 2 mod to my MM with a liquid cooler sandwitched between the boards (pressed for room in a 1/10 buggy I'm running, very little air flow without perferating the body)
The most lipos I've heard or seen was only 15S. The lower Kv motor will produce more torque than the higher Kv ones. I forgot to mention the Neu 22xx that might fit the bill as well. I will be putting together some form of liquid and Peltier cooling system. I already found a few manufacturers of mini water pumps. I've also spoke with a couple manufacturers of Peltier devices that can custom make them to fit around non finned motors. All I need to do now is find a source for the radiator (Water cooled heatsinks) for the ESC, motor and the whole cooling system. I'm still trying to figure out the most reliable way to go about doing it.
