MetalMan
MetalMan's Avatar
03.24.2008, 02:15 PM
Originally Posted by Sammus View Post
So the two suspension pin holes on either side arm mount in the picture are for the two different toe settings? surely not.. it looks like they would significantly change your track width and you would need different length CVDs and all? or Is one set of holes used for the extended arms or something?
I was under the impression that you get different pairs of arm mounts for different amounts of toe in, and my question was, how much toe do the arm mounts have in the tranny kit in the RCM store? :P
Ah, it's those holes you were referring to (I forgot about them). One set of holes is just to extend the width by something like 1/4" per side. You don't have to do that, though, if you already have suitable dogbones or CVDs. These holes do not have anything to do with the 1 or 4 deg. of toe.
I can't tell which mounts those are.
