03.24.2008, 09:02 PM
Are you using a drill press to drill the holes? If so when you clamp the piece to drill, leave it in place and chuck the m3 tap in the press. Then just feed the tap down into the hole and turn the drill press by hand. I usually open the lid and use the pulley to turn the tap into the material, much easier than doing it by hand, and the tap is always perfectly lined up with the hole.
Looks good, are you going to build some sort of battery holder?
