03.24.2008, 09:05 PM
Or you cold use a few spacers to move the motor plate away from the upright portions of the motor mount. That would place the motor closer to the spur and you could use std pinions. A 10mm al spacer, like a cable stop would do, just make sure to buy longer bolts and use thread lock to hold it all tight.
