03.24.2008, 09:07 PM
1 tooth drop on the pinion would not be very noticable and may help heat issues. 2 teeth would most likely do it, but that would knock off a few mph.
Just get a novak 2700 cap and solder it to the main leads close to the board. That may do the trick, and costs about 10 bucks!
Also, reattaching the heatsink properly will help too, the stock thermal glue is not applied very well.
