bluonyx
03.25.2008, 10:36 AM
Originally Posted by Patrick View Post
I just put a small cable tie or piece of wire (not electrical wire) through the little hole in the shifter shaft then wrap it around something near by, so the shaft stays pushed in (for second gear).
I just use a Collar to lock it in second. I have the shaft pulled out and the collar on the shaft to keep it from going back in.
