speedracer1129
03.25.2008, 08:58 PM
Ok, quick update. I have discovered the problem. No, it was not the gearing (thankfully)!! The problems is that the batteries have no balls!!! I lost 4.5V under load pulling 124amps. So what kept shutting down the system was the LVC!! You think that Quark would have put somewhere what the blinking lights mean..... Neverless, I am happy that I have confirmed this with Quark. I also tested another car with a 4S setup on a Feigao 2pole setup with lower gearing and got the same problem. So, I am going to double up the packs to run a higher C output on the 4S setup to confirm the problem, which hopefully will put everything back into high gear!!
