kingiggy262
BL-Revo
03.25.2008, 09:06 PM
Yeah, I don't particularly like charging high currents through the balance taps as they aren't designed for that kind of current flow, but from I gather, the FMA 10s charger works like most of today's chargers: main charge current goes through the main leads and the balance connector is used for balancing and cell monitoring...
Yep, it charges through the main leads and balances through the balance connector. You can charge only through the balance connector but it will be limited to 4 amps max charge compared to 10 amps with the main leads. When charging you plug in the main leads from the battery to the charger and also the balance connector to the charger at the same time. During charging it will tell you the amount of maH put back in along with the internal resistance of each cell and the current charge rate.
I am still waiting for the PC interface cable so that I can view all the information while charging and even change settings on the fly from the computer. I have only had this thing for one day and so far I am really pleased with my purchase!
For a DC power supply I am just using a normal PC power supply that I had from an old computer and then installed banana jacks. It can output up to 25 amps so it has no problem supplying enough amps for charging.
